the 1994 z34 is OBD1 correct? If not what is it? Neither code readers will work in the data port. When I do the On Board SES light flicker thingy it doesn't even work if I jump the connectors like the Haynes manual tells me to.. whats the deal here?
Stupidist Question of All time!
if it makes you feel better that is not the stupidest question i have ever heard. i think the mymonte site has the dumbest lq1 questions i have ever read. one in particular was one guy asked where the wp pulley was iirc.The Official Rotating Mass Nazi
You dont use an obd 2 scanner. You need a gm plug and you can pull up all the info needed, ex, ses codes
I have a 95 in which I have the OBD 1.5.
I bought a Actron Scanner that reads OBDI and OBDII and I just use the OBDI connector to read the codes from the car.
OBDI you can use a paper clip, but with the OBD 1.5 you cannot use a paper clip. Have to use a scanner. I tried taking my car to Autozone and they don't have the equip. to read our cars neither.
Autoxray works great mine also.
There are no stupid questions.Getaway cars:
1986 Fiero SE | 2.0 OHC Turbo/Intercooled | MT2 5 Speed - 1994 Dodge Stealth | 6G72 SOHC 12v | F4a33 - 1999 Ford Windstar | 3.8 Essex | AX4S -1998 Lexus SC400 | 4.0 DOHC 1UZ | A650E
