I have a 96 motor going into a 88 Fiero. I am using the 91 harness/ECM on the motor (i have a manual trans and need the manual trans ECM)..
Anyway... as i am putting the harness together with the 88 harness i have found that the EGR, Alt and fuel pump connectors are differant. I have not checked all, but i know these are.
So, can i install a 91 Atl in place of the one on the 96 motor.... will it bolt on no prob??, Can i remove the 96 EGR and replace it with a 91 also. In other words, will it bolt up and work correctly.
Thanks
Rob
Thanks
Rob
![](http://pff.hostkansas.com/pffimages/on_cradle3_1.jpg)
