Today I was at my parents house and when I left I Did a big smokey when i left shifting the gears man, and when it hit 2 it hit sorda hard. Well about 5 mins down the road me and my friend both smelled burning coolant, so we pull over and pop the hood. There was coolant burning off the crossover pipe, down by the COOLANT TEMP SENSOR right around a one of the bolts that hold the top mount to the cylinder head. or at least thats where it looked it was coming from. So we went to the shop lifted it up the very you could see where some coolant had beeing leaking around by the very bottom bolt of the upper mount I hit with a wrench real quick it tunred a little bit. We drove it around for a while burn about a 1/2 of gas just driving around seeing if was going to leak again. I dont see ne thing leaking any more or do i smell it burning off. Anyone know if that bolt is ran into a water jacket and i should try to pull it out and put sealant on the bolt and run it back in???
here is the bolt im talking about
