Hey all,
Got my rebuilt 3.4 DOHC engine installed, and I'm so close to finished I can almost taste it. Currently it cranks, but it won't start. Here are the diagnostics.
Fuses:
ECM/FUEL: +12V
DIS: +12V
INJ: +12V
ECM diagnostics: Code 12, test OK - no other codes
Fuel check: 4 gals fresh gas (total at 1/2 mark), pump runs, good pressure at schrader valve on fuel rail
Spark test: Tested on cylinder 6, arcs to ground when cranking.
New Bosch platinum spark plugs and 7mm wires.
Next troubleshooting steps?
Thanks,
Dave
Fuses:
ECM/FUEL: +12V
DIS: +12V
INJ: +12V
Thanks,
Dave
