I have a 96 Monte Carlo Z34 with 129K miles that hasn't been giving me any trouble besides the occasional P0410 code. The last time it was driven was Monday this week. It always sits outside and it wasn't driven at all on Tuesday. It's been very cold this week, single digits, but it's started in weather as cold as 10 below zero with no trouble before and I've never had trouble starting it in cold weather. I started it up on Wednesday to move it out of the way and it started like normal. Thursday I go to start it and it won't start at all. I can hear the fuel pump fine and it turns over fine, some cylinders are hitting, but not all at the same time. It sounds like it's close to starting sometimes, but just can't. I tried scanning for DTCs but there's none in the computer. I've checked everything I can think of, spark plugs, wires, fuel pressure, haven't looked at the injectors (but to have all six to go out suddenly?) and I know they're getting fuel to the cylinders because the plugs are wet when I pull them out and there's vapor coming from the cylinder. Can anyone give me some suggestions? I'm totally lost to this one and really don't wanna take it to a dealer. I'm to the point where I think the timing belt may have jumped and the cam's outta position. Thanks
96 Monte Carlo Z34 turns over but won't start
Have you ever had the timing belt changed on the car? When was the last time? 60k is the OEM recommended mileage, but personally, I wouldn't go that long. If the plugs were wet when you pulled them out, it sounds like they might not be getting a spark. Hope this helps some.-60v6's 2nd Jon M.
I pulled the cover off the timing belt earlier today and it's in really good shape. I cranked it over a few times to look at more parts of it and I couldn't find any cracks or worn or broken teeth. The belt's never been changed as far as I know, I bought it when it had 34K miles so I doubt the previous owner changed it. As far as the plugs go, I tried putting in new ones in the front 3 only since the back 3 are a bit of a pain to get to. That didn't make any difference, I should at least get some firing with 3 plugs sparking right?
Originally posted by DFreshI pulled the cover off the timing belt earlier today and it's in really good shape. I cranked it over a few times to look at more parts of it and I couldn't find any cracks or worn or broken teeth. The belt's never been changed as far as I know, I bought it when it had 34K miles so I doubt the previous owner changed it. As far as the plugs go, I tried putting in new ones in the front 3 only since the back 3 are a bit of a pain to get to. That didn't make any difference, I should at least get some firing with 3 plugs sparking right?
On another note, change the Tbelt. The 96+ engines are supposed to be intereference. When that belt breaks, and it will, you could potentially ruin the valves because they may strike the pistons.1991 Grand Prix GTP LX9swap/Getrag 284 --- SOLD =(
1994 Corvette LT1/ZF6
2006 Dodge Dakota 4x4 3.7/42RLE
Originally posted by jmgtpOn another note, change the Tbelt. The 96+ engines are supposed to be intereference. When that belt breaks, and it will, you could potentially ruin the valves because they may strike the pistons.-60v6's 2nd Jon M.
You can check the front cams easily compared to the timing mark on the crank pulley. The front intake cam is the one your fuel is based on for SFI operation. I thought startup was batch fire but maybe its SFI...i dunno.
It could be your crank position sensor is getting messed up, or the wiring isn't too good.
That belt needs to be changed so regardless of what you wanna do with the belt, its your best interest to change it and the idler pullies, tensioner, and tensioner pulley. im not 100% on your engine being interference but its possible given the close tolerance the older DOHC engines are for your valves to bend either way. Its possible they wont, but I wouldn't take that chance.
Have you checked your fuel pressure? Maybe your pump or FPR are causing your current problem.Ben
http://www.60degreev6.com/index.php?p=pages&pid=3 and
http://www.60degreev6.com/index.php?p=pages&pid=62 will help for sure. I deleted my last post because I forgot about the mileage on the belt and pretty much contradicted what I had said before, lol. Those two links (first one tells how to make cam hold down tools, and the second one is the timing procedure) will help you out alot. If you can, I would suggest getting the DOHC special toolkit if you can find it on ebay (they pop up on there from time to time) if you plan on keeping the car a while longer.-60v6's 2nd Jon M.
Anybody know a place that I can get all the parts from? I checked partsamerica.com (advance auto) and o'reilly's websites, but they can't get them. They do show an idler pulley under heating & cooling, but that's not the same right? Thanks for all the help too.
Ok, I replaced all the spark plugs & wires and put it back together. After I tried to start it, it fired and turned like normal for a second then died. I tried cranking it over again and was getting some firing again. Next I tried playing with the throttle and after putting the petal to the floor it started up. The idle was fluctuating a little bit and it would dip a little sometimes, but no rough running or misfiring. After a couple minutes I turned it off then tried starting it again and had to give it throttle to start. After shutting it off again and trying to start it a third time it started normally. I hooked up my OBDII code reader to it and it's giving me a P1406 error code with is "EGR Valve Pintle Position Circuit". I believe this rules out the timing belt now. Anyone have any ideas on this. I don't wanna buy a $160 EGR valve for nothing.
Take the EGR off and clean it out as best as you can with a tooth brush (I hope one will get in there, but I have no clue because both of my cars have the digital egrs, not the linear one) and some carb spray. Spray some in it and let it soak for a while before trying to clean it, so it has time to break up the crap. If that doesn't work, your EGR passage in the plenum might be clogged up if the EGR is ok.-60v6's 2nd Jon M.
I just took it for a quick 8 mile test drive and it ran great. Gonna leave it parked outside to see if the cold will mess with it tonight. My car has a digital EGR too so I'll take a look at it when I get a little more time this weekend. I did come across a blown fuse for the Air Injection Reactor pump. Could that have been the root of the problem? It didn't start right after I replaced the fuse but I was wondering if it may have someting to do with the EGR valve or could've affected some other sensors.
