Hi im new to the forum and think its a great resource site I LIKE IT ..
Ok my problem si.. i have a 1992 chevrolet lumina euro 3.4 wich i bought not to long ago.. so i changed the belt and it was runing perfectly(it had a little misfire once in a while (even after the belt change) but then it stoped when the engine heated.. all the timing is right... so the next day i started the engine and the cilinder 2 does not work and the idle was at 2000rpm.. i checked the spark plug on the cilinder and it had spark and was dry like if no fule was going in.. another thing is that when i turn off the engine and turn it on the first seconds it work perfectly and then it starts to missfire again(number 2 cilinder actualy stops working) and after a few second the check engine lighte comes on and the engine accelerates even more... im checking if there are any vacume leaks or somthing that is keeping the engine accelerated but dont know exacly where to look
iv been cheking if i could of unpluged somthing while chaging the timing belt.. i saw that there is a sensor that if u unplug it the engine turns off.. i think its called a map sensor.. i took it out and cleaned it also chect if it was making good contact..
i dont know it looks more like an electrical problem ill check if its the injector tomorrow..
i dont know if the cilinder 2 not working has anything to do with the high idiel
i live in spain so geting parts for this car is very dificult so anything i can do without replacing parts is better
any tips or advise will be of good help
