The fuel hose has to be put between the lifters against the "floor" of the cam carrier. The problem is the spark plug "tunnel" is in the way of pushing the hose straight in at a shallow angle, so you have to start the hose in on a steep angle, then turn in underneath the cams staying low between the lifters.
See the attached pics.
Hope this helps.
Hope this helps.
