First off, HELLO to all in this forum. I am new to this forum, but not to others.
I have a 1995 Monte Carlo Z34 3.4 Litre with 105K miles, which I bought 6 months ago. The engine is surprisingly powerful for a V6 and I love the car. I hope to keep it a long time.
I checked and found out the Timing Belt(TB) had never been changed by the previous owner so I knew that had to be done.
After the weather turned cold in NE Ohio, when I start the car, the RPM's will go up to 3K, then down to 500 RPM, sometimes stalling. After the engine warms up, it runs fine. I did a little research and found out about the intake gasket problem. So that went on the to do list.
I bought all the timing belt parts (belt, both idler and tensioner pulleys, tensioner, gaskets) and intake parts (new style gaskets) as well as spark plugs and wires. I also bought a set of factory manuals.
So my Son and I started in on our 3.4 Litre. We have removed everything needed to get to the TB to change it.
When we removed the spark plugs, all three rear spark plugs exteriors were coated with oil. The plug section that's inside the engine was dry and had a white powdery coating on it(and all the other plugs as well).
We rotated the engine until both front cam flats were upright, and used the Kent Moore (KM) hold down tool to check they're flat and also tightened the tool down. The timing mark on the dampener lines up perfectly with the engine cover pointer.
When we tried to loosen the front LH Intake cam sprocket bolt, it would not loosen using either an impact gun, or a breaker bar. Is it a left hand thread?
Anyways, after reading AutoZones procedure for TB replacement, it states to clamp the sprockets so they don't move. I used my other KM hold down tool to clamp down the rear cam even though the flats are not pointed up. After we removed the timing belt, both cams are rock solid according to the marks we put on the sprockets.
When we installed the TB, we found the rear sprockets seat the TB perfectly,but the front sprockets are a 1/2 tooth off. What I mean is when one front sprocket has the TB seated properly, the other sprocket's teeth has the TB teeth sitting directly on them.
Well, that's where we're at. I don't know what to do from here.
I do know I want to do this repair properly. Any suggestions would be greatly appreciated.
TIA,
Jogasz28
TIA,
Jogasz28
