Hi guys, I just want to say that this one awesome forum. Lots of info and opinion concerning our beloved 60* V6 power plants.
Now for my question.
When spring finally breaks, I will be changing the timing belt in my 93 Z34. At the moment,m it is running just great with a couple of minor exceptions, (occasional SES light referencing an ERG code and an ANTI-LOCK light that comes on between 68-72 mph). I bought the car with 87k miles on it , it is now at 107. I have NO idea when the timing belt was last changed, if ever, though I see someone had the inspection cover, as evidenced by the oddball fastener holding one end of it down.
I have read and thoroughly understand ALL the information regarding changing the belt, but I do have to wonder a thing or 2.
My idea was to prepare the enginf for the belt change, set #1 to TDC, etc. But I am unsure if it is REALLY necessary to go through the entire cam timing procedure, my reasons:
1. If the engine is running and the cam sprockets are that difficult to remove, they shoudl not have moved at all, so there SHOULD be no reason to retime the sprockets to the cam.
2. With the engine set to #1 TDC, you should be able to slip the old belt off and slide the new one right back on and be in good shape. I know there is most likely some bels stretch that must be accomodated for, this is where my next procedure applies.
3. Before removing the old belt, mark places on both the sprockets and the belt. Then simply transfer those marks to the new belt, and align them all.
For instance, starting at the drive sprocket, count the number of teeth between the mark on the drive sprocket and each subsequent mark on all sprockets. Then, mark the new belt at the corresponding teeth on the new belt and install, aligning the marks on the belt with the marks on the sprockets.
Now hang on just a minute before going ballistic. The key here is NOT to transfer the marks from the old belt to the new one by measurement, but by belt tooth count. Since the sprockets and belts have a certain and identical tooth pitch, the cam timing will be set correctly which will eliminate any out of time condition due to belt stretch.
Any thoughts on this?
Thanks!
RED
Thanks!
RED
