waterpump redesign
  • waterpump redesign
    when putting a rebuilt engine together i decided to spring for a new waterpump and with it came a TSB showing that it is completely redesigned over the factory ones.
    i figured i would let everyone know in case any1 was rebuilding their engine or debating on a new waterpump.
    i am assuming it is better than the old design.
    I hope you are not referring to this style pump. http://60degreev6.com/showthread.php?t=31924 If so, then enjoy your new overheating problem because this design does not work on the DOHC's. I have personal experience with this issue. Go back to the old design.
      whoa, that "redesigned" one has an impeller that many import waterpumps use (usually driven off the timing belt)
      Brian
      3400 SFI V6, 4T60e
        i see i may have to take this TSB to the dealer to validate if in fact gm did redesign the impellers. thanx for the heads up.
