As some of you may already know I recently had some issues with coolant dumping into my engine. The oil came out looking like chocolate milk. I priced out the new gasket kit $226 and figured I should probably do the timing belt while i have the top of the engine apart, priced that out today (using part numbers in the Cam Timing Walk through) $733.90, for a total of $959.90 plus taxes, and this is if I do the work myself!! (the wreckers quoted me $950-$1200 on a new engine that they garentee to run)
After I get all that work done, I'm still at risk of blowing out the bearings am I not? (thinking coolant may of stripped them of their protective coverings) not to mention the timing on this engine has me scared $h**less
I dunno what to do and I would really appreiciate some input here. Another option for me would be an L67 swap, but that too is a lot of money and work.
*edit*
should I maybe just do the gaskets and leaving the timing belt stuff for later if the engine survives? I just hate the thought of ripping into this engine again and again...
Jamie
*edit*
Jamie
