simple question - how many lb/hr are our injectors rated?
what # injectors do we have?
They are all the same to the best of my knowledge. I know you can use 95 injectors in a 91, so they are damn close if not exact anyway. The 23# is for 91-93 for sure. I can check the 94-95 code and see if the injector constant is the same. Im not sure yet if it uses the same formula, so ill ask brian about it as well.
96-97 I have no idea on. Their FPR is adjustable according to michael, so its possible they are the same rating but then use a higher pressure to make them higher flow. Anyone with a 96-97 could check their pressure and we would know if thats being done anyway.Ben
Originally posted by AaronOriginally posted by 4spdz34260hp is it aaron? with pulley, tunning, ported heads/intake, -13* on the exhaust cams you should be able to get that-60v6's 2nd Jon M.
Originally posted by AaronSappySE107, do you think that we will ever need to upgrade our fuel system, N/a, with the headers and full head and intake work? I hope to make around 260hp with all this, can our fuel system keep up?
Desktopdyno tells that I have 307hp@7500 true? Dont know, should be like 260rwhp in a dyno. So far the kevlar clutch dont hold, to be more exact its near dead and was intalled in oct last year.
DreX
