Added HP
  • Added HP
    I was just wondering if you can bypass the AC Unit.
    You would need to put an idle pulley in its place but it is possible as its been done. I believe there is a part made already to do this, but by itself its not going to give you any power.
      Re: Added HP
      AC Unit you mean compressor? Like Ben said all it will do is reduce drag on the motor, it might free up some horsepower like 2-5.
      1992 Lumina Z34 | 3.4L 207ci DOHC 60º V6; Getrag 284 |
      1994 Pontiac Grand Prix GTP | 3.4L 207ci DOHC 60º V6; Hydra-Matic 4T60E |
        Not at WOT. Its not enabled at wot so it is an idler pulley as well at that time.
          well it might help with weight reduction then! :-D
            No shit, well you learn something new each day.
              yep yeah it does, you can even notice it...the temp changes out of the AC vents if your flooring it on to the HW
                plus it allows more room for the intercooler
                87 merkur v8 *fast wont come close*
                67 c-10 slammed and quick
                01 sc2 beater with a heater
                couple crotch rockets and other toys
