From what I?ve heard all of GM?s pushrod 60 degree v6s share external dimensions and mounting points. Which is why it?s possible to swap out that the ancient carbureted 1984 2.8L for the SFI 3.4 from old v6 f-bodies, electronics & transmission not withstanding, it should bolt right up. My question is does this hold for the dohc v6s also? Does the LQ1 have the same mounting points as the other 3.4s? What about the 3.6L? I'd much rather go with the doch from a z34 than an old 160 hp f-body engine.
Is the 3.4 dohc the same size as the pushrod '60 deg's???
That page has a few links of a 3.4DOHC vs a 2.8.
The DOHC is a FWD only engine so I believe the starter is on the opposite side (front or right side), the mounting bosses in the block should be similar or the same. The problem with fitting a DOHC in a RWD app is its width, those cam towers add quite a bit of bulk up there.
There is a guy that is/was doing the swap into a f-body, maybe someone else will remember more of that.
Originally posted by brian89gpThere is a guy that is/was doing the swap into a f-body, maybe someone else will remember more of that.-60v6's 2nd Jon M.
