do the 91-93's have the same huge ass damper as the 94+?
also let's say you have your rotating assembly balanced, is there still a need for it?
since i am running a 91-93 harness now, could i cut the rubber stuff and remove the outer ring and just keep the hub since the 91-93 doesn't even use that sfi stuff?
lastly say i do not need it, what do you guys think if i got a crank hub off of say a lt1 motor and just had a custom pulley made to match a specified diameter?
