power to manual seat conversion q/a
  • power to manual seat conversion q/a
    my gtp has the electric seats in it and i was wondering can i just change the sliders out with a manual set and be done or do i actually have to find another set of seats?
    I believe it is an assembly and is replaced as an assembly and manual tracks can be swapped in.
    I am back
    Mechanical/Service Technican
      What year Grand Prixs came with Manual Seats?
      1995 Pontiac GTP
      Over $12K invested, and still its slow. Maybe thats because thats most all repairs. Don\'t knock the engine though, because thats the only part that has seemed to last.
        well your in luck... i have played with many seats... and just finished installing cutlass seats in my Monte.
        I converted the pass to power.the seat pans are the same even from the cutlass to the monte carlo... and that was a 92 cutlass and a 96 monte.
        so since your GP is a 95 and also a Wbody and it is a 1st gen Wbody too. the seat pan should be the same. that mean you can swap the power for sliders at will....
        I did have to do some slight modifying (drill one hole for seat recline) because i was using a drv side slider on a pass side seat.
        So if you add a slider, you will need to get the correct slider for the side seat you are going to use it on. im assuming since you are getting rid of power that it is the drv seat your converting... so you need to find a non power drv seat slider
