group buy lq1 aluminum timing cover
  • #76
    that's all i had some1 do. every1 has a pattern too. it is made of plastic. if some1 else did it, that would be awesome b/c it shows that there is still some interest in this engine out there.
    perhaps if you guys ask brad nicely, he may do it.
    • #77
      sorry due to the bad short term memory i finally got the extra boxes i need and will have the final 2 quotes tomorrow.
      • #78
        Got mine today. Gotta say, it certainly looks good. The cuts were very clean and smooth by any standard. Your machinist, though it took a while to get to it, did a *very* good job. Now, if only my engine wasn't on the other side of the country, I'd like to fit it, and see how it looks in place.
        Thanks Bobby!
        Certainly worth the price, I couldn't have done a better job myself. It would have taken me much more effort then the price of yours would have justified. The flat pack held up ok in shipping, but I did have one edge poking out a bit when I got it.
        • #79
          if i can get an hour or 2 off work next week. my motor too is in pieces although a little closer.
          if i can, i will pick up my entire timing cover and test fit mine and let you guys know.
          i appreciate the compliment fiero obsessed. i also talked to ez112. he too has recieved his but i haven't heard from napatiger. his will probably show tomorrow since he is in cali.
          i hope it is ok. he has standard packaging with the 1/8 cover at his request even though i recommended the wood. turned out to be only 1 dollar more. go figure.
          • #80
            very nice.....
            95 MC Z34 Black
            • #81
              got the final 2 quotes today.
              hey mike, glad is showed up ok.
              jon is $15
              nolan is also $15 but you have a +$24 with me so that takes you to +$9 and i will ship monday since i have your addy now .
              • #82
                Thanks.
                Take the $9.00 and have a beer or two on me.
                Nolan
                • #83
                  a beer or 2? 9 bux should get 12 of them . but i am good though. thanx for the gesture. i will just apply it to the cam cog covers.
                  but if i get the urge(and time off and $$$) i may go up there again and maybe look up some of you peeps.
                  • #84
                    nolan and jon are sent out. only one left is travis.
                    • #85
                      Excellent! Look forward to getting it. Are you sure about the beers?
                      Nolan
                      • #86
                        Test fitted it tonight. Fits PERFECT!! Will post a pic in the morning.
                        The 1/4 thick covers may have a clearance issue with the p/s pulley. May have to take a little off were the P/S pulley passes over cover. Or run the P/S pulley .010 ~.030 farther out on the pump shaft.
                        1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
                        • #87
                          god damn that cover of yours looks nice. i just looked at a pic of the excess area that i noted on arrival. the pws "hump" as i call it is within tolerance and probably will not even need to be grinded down as i originally thought.
                          2 out of 2 batting 1000 so far woohoo!
                          jason(even though he took his time) didn't let me down again it seems. i will probably stick with the guy even though he does take his time for future stuff.
                          only exception will be the 1/4 guys it seems but i gave plenty of warning be4 i took the orders.
                          it may be ok though b/c your id was 3/16 which is only 1/16 off from 1/4. one of you 1/4 guys has to bolt it on and lmk.
                          that leaves sourmug. have you recieved yours yet?
                          • #88
                            • #89
                              • #90
                                Wow, that looks great!
                                Nope, I haven't seen hide nor hair of it yet. I suspect that it will take some time to get through customs. I'll let you know when it arrives.
                                Nolan
