Fuel Rail & Injectors 94 & 96 the same?
  • Fuel Rail & Injectors 94 & 96 the same?
    Hoping someone with knowledge on this can help me out. I am wanting to
    replace my Fuel Injectors & Fuel Rail on my 1994 Lumina Z34. I would just have injectors cleaned at WhichDoctor as advertised somewhere on this site, but it looks like at least 1 is cracked, and the others look pretty old ...162,000 mi on them.
    I came across this auction on ebay.
    My question is, are the Injectors the same and will the Fuel Rail also be
    the same size and bolt right up on my car? I am guessing that i could use that regulator on the fuel rail as well, but if the Rail and regulator are not the same, i could at least take off and use the Injectors on my old Rail if they are the right ones.
    Any input or ideas or maybe a link to cheaper ones would be appreciated.
    Paul
    94 Lumina Z34
    Moved Wife & Kids Out So I Could Have More Room To Park Z34 In Livingroom.
    RE: Fuel Rail & Injectors 94 & 96 the same?
    injectors...yes. rail.....no. shame i threw away 3 rails a few months back b/c no1 wanted them even for free. one of them was a 94. i may have a set of injectors for you though. i will have to check. if i do i can let you have them for 25.
    as far as a rail is concerned there is a junkyard i can go to get one cheap if that is a route you'd like to go but you'd have to pay for gas and it would be non-refundable even if they do not have any 94-95's
    **insert shameless plug**
    hey, would you be interested in a bolt-on kit for a lq1 oil cooler and external tranny cooler?
    just figured id ask since they didn't come on any 94-97's 50 bux if you want them both.
    i am also a reputable seller just check the thread and u might see my name a few times
      Hey friend, thanks for the offer but i guess im gonna go with new if
      i go through the effort in pulling this plentum off again. I just wanted
      to make sure they would work, as i thought i heard that they had
      different flow rates between the different years. I don't really remember
      what it lookes like (been a while since fuel rail was exposed on mine) but
      is there a chance that i could also rob the Fuel Regulator off the new Rail
      and put it on my old one? Different...Same...or Not Possible?
      Thanks again for any input, Paul
      94 Lumina Z34
