Towing: 94 w/3.1L + 4t60e...
  • Towing: 94 w/3.1L + 4t60e...
    Hi, Fellas-
    OK, I've read a few posts about towing and hope I'm not pressing my luck given the history with my 94 Cutlass Supreme. But, I'd like to occasionally tow an 850# tilt trailer + 750# Harley and looking for suggestions.
    I've found Class I & II hitches (JC Whitney & others) with up to 300# tongue & 3500# overall weight. My convertible is heavier than most @ 3650# and probably has the 160Hp 3.1L V-6 w/180-185#ft torque. I guess the load is in the 6000# range w/fuel, 2 riders & supplies. I don't expect this is a problem on level ground, but Washington has a few hills to climb. Will the car really pull this much [at any speed]?
    I know heat is my enemy and I don't want to melt my tranny, so I've considered an external cooler. (Suggestions on size and installation [before or after radiator]?) What about products like Redline Water Wetter or similar that proclaim to reduce operating temps up to 30deg? I know of some heavy duty shift kits, but installation is probably beyond my ability/wallet.
    The majority of my towing is done w/96 Ford Bronco XLT, so I don't have to use the Cutlass. But with fuel costs climbing I'd like to use use it if I can. Anyone done this successfully (or unsuccessfully)? I really appreciate any/all suggestions/feedback. Thanks again,
    Eric in Tri-Cities, Washington
    RE: Towing: 94 w/3.1L + 4t60e...
    I don't have any hard evidence for this, but I once heard the the towing capacity was 1000 pounds. I believe it was Shawn who said that. I'm not sure if that was pertaining to the TDC or the 3.1, but either way, I'd stay away from that.
    BTW, I've heard that water wetter is an excellent product.
    92 cutty auto with a 97 3.4
    93 convert with 3.4
