1/4 mile times
  • 1/4 mile times
    Ok, i decided to test out some equations found online, and some i learned in physics to see if i could get a rough estimate on the horse power of my car. I used DYKZ34 1/4mile times and dyno hp as a base to run through the equations and see how accurate they were. They come within 1-1.5% accuracy unless i did something wrong.
    I have heard to estimate a loss of 20% flywheel horsepower over the drivetrain.
    I used 3200lbs and wheel hp of 179 and came up with 15.23 in the 1/4 in the equations for dykz's car. His time on the timeslip was 15.38 so that gives it about a .5% accuracy.
    I raced a 2000+ GP GT with some exhaust work and possibly other mods last summer and beat it, his bumper was at my door from 0-90 the entire race. I estimated he should run about a 15.5......is this reasonable or no? The came to about 179hp at the wheels.
    Off that estimate i estimated my time to be a 15.3, in which case this gives me, with the wieght of my car puts 213hp at the wheels. Which is ALOT more than DYKZ's car.
    Was I too generous on the times given to the GP and my car? I think i was because I dunno why my car would have that kind of power at the wheels with these mods:
    FFP Pulley and dog bone
    Exhaust 2.5" Cat back Magnaflow
    Gasket matched intakes
    K&N with holes in box
    Bosch Platinum Plugs
    Using my 1/8 mile times and driving with a blown head gasket i was able to calculate 177 wheel hp.
    Anyone care to check my work and please prove me wrong?
    www.cardomain.com/id/topless94style
    RE: 1/4 mile times
    I suppose I should show the other numbers I used:
    My weight 3800lbs
    1/8 mile time: 10.6
    1/4 mile conversion: 16.4
    GP GT guesstimate hp @flywheel: 224
    GP GT guessed weight: 3400
    GP GT @wheels: 179
    Equations used:
    For 1/4 time(my numbers should be corrected, this is for a good 60' of 2.2 or less, mine was about 2.4-2.5):
    5.825* cubed root of weight of car divided by hp(wheel hp)
    For HP:
    Weight*(MPH/234)cubed
    I converted my 68mph 1/8mile trap to 84.3 1/4
    Estimated power:
    P= (.5*mass in kg*velocity in m/s squared)/time
    P = watts
    1 hp = 746 watts
    P/746
    then for some reason i multiplied by 1.8 and got pretty close on the wheel hp...within 1.3%
      Man! That is a lot of cypherin'! You crushed a bunch of numbers! My last run was 15.94 @ 89.4 MPH. Pretty much stock. What you have to realize is, advertised HP, is for sales purposes, done on a static engine dyno. We don't have 210 HP on the track. Bottom line is,... Averages: 5040 RPM,.. Wheel HP,..130.6, Wheel Torque...136.6 Ft. Lbs., Correction factor,...1.023, Speed,...95MPH. Now the MAX: 5928 RPM,... Wheel HP,..154.6, Wheel Torque,...174.0 Ft. Lbs., Correction Factor,...1.023, Speed,...120.1 MPH. CF is calculated at optimal weather conditions. 70* at sea level. There is another "Dyno" out there, that will give you better numbers, but, let's just say they are fudging a bit. 94 Cutlass, 3.4 DOHC, 4T60-E, Hi-Flo cat, Borla Cat Back. (CAI isn't a factor in a static test) These numbers suck in a way, but, the DOHC still is a Bitch of a 6 Banger!)
        BTW, I like your car.
          do I hear bells??
          I wish 10% of the people on the road knew how to drive
            Uh...Nope..Exhaust.
              Ha ya 3hrs between classes and not wanting to study will lead to thinking...especially after physics.
              I understand that hp numbers can be used as advertising techniques, but where are you getting those numbers from?
              Thanks for the comment about the car by the way.
                my 96 ran a 16.5 1/4 with intake & Exhaust
                Donesic Disurbance
                Grand Am 3400
                  I had my car dynoed Saturday. That's where the numbers came from.
