Can u still get a new 3.4 DOHC?
  • Can u still get a new 3.4 DOHC?
    I'm new so i dont know most of this stuff. I was reading through some of the other topics and i came upon a "built" 3.4 DOHC. It stated that it was new. I was wondering how much they are if they still sell them new. Thanks
    Kyle
    1992 Lumina Z34
    5 Speed
    Autozone civic intake
    Ultra White lights
    FFP Dogbone mount
    125k miles
    2.5 inch Magnaflow catback from Magnaflow cat
    60degreeV6.com Custom Chip
    Our local dealership either has, or has access to, them. They are $4200 long block, and no core charge. Too much IMO, you can spend under $2,000 on a cheap rebuild.
      It's not that my car needs it. You posted on my car under members rides. I was just thinking if anything went wrong with it because it does have 147,000 miles. Thanks
      1992 Lumina Z34
      5 Speed
      Ultra White lights
      FFP Dogbone mount
      125k miles
        Ebay has them now and then, for less than 2000. I would still take a quality rebuild because you can balance the bottom end, deburr and shotpeen the rods, go with tighter tolerances, and end up with a stronger motor. That and with a well seasoned block, you are in better shape for the long run as well. However it takes longer to do that and you need an engine to work with.
          I agree, it would be the better route. But hopefully you don't run into problems before then. I ended up having to replace my crank, rods, and pistons, and some other small stuff therefore my tally, after all was said and done, peaked $3,000 and neared $3500. BUt it was worth it, this motor cranks!
            Actually Gm has now discontinued all 3.4l dohc's ive checked into it.
            Jake
              That was sometime ago.
              I am back
              Mechanical/Service Technican
                A few months.
                Jake
                  Here Kyle, this might go cheap enough.. http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
