Is this a problem with these vehicles, if so what turned out to be the fix?
96 Monte Z34 Window Dead
Hey. Not sure if you checked MyMonte yet. But, this is super common on our cars. The switch gets wet if it rains/snows w/the window open (or opening the door) and will eventually die. I've had to replace mine once, along w/ most of the guys over at MM. Expensive POS switches they put in...haha...
Edit: Oh. Also, the Auto-Down on the drivers switch will sometimes stick, causing the window to keep trying to go down at the stop (which in turn yields you not being able to put the drivers window up).
WMZZZ1995 Monte Carlo Z34 - 3.4L
1980 Trans Am - 6.6L 400, 428 heads
The other day I was driving to a fast food joint thinking geeze I wish my window would seal all the way and I was playing with the buttons thinking there may be corrosion inside and since they are self cleaning switches pressing them repeatedly would do the job. Suddenly the window went all the way up and the little air sound around my window went away. So the little devil in me thinking well if it worked for up well it must work for down. So I repeated clicked on the down button and sure enough the window started to go down. YES! I thought and then I tried to make it go back up and low and behold the switch worked but the window just made this weird clicking noise. Ah Crap I thought its like subzero outside. So when I finally got to McyDs I helped it up the rest of the way. So no more wind noise from my window but its something inside. Anyone have any ideas? Oh and by the way I tried MyMonte.com and even though I registered a million times I never got a confirmation email even after emailing the admin. Anybody have some pull with the admin to get my account fixed for wiserocz? I'd like to post but cannot.96 Monte Carlo Z34
92 Chevy Blazer LT
85 IROC-Z
92 Olds Achieva SC 3300 (For Now)
i have replaced both motors for 1993 cutlass and both in my 1993. I think it might be a problem, what do you think? :-0
I haven't really had a problem with the windowswitch, but have had to replace the switch because of themirrow switch.[b]Stan [/b]
1994 [i] White Cutlass Supreme Convertible[/i] 3.4 DOHC
Add Ons: Overhead Display, Digital Dash, Trip Computer
