this is for any1 thinking of putting a 96-97 dohc into your 94-95(i have a 94 btw) using obd1. but a good portion of the info if not all of it can be used for a 91-93 as well.
1st thing i had to do was bypass the air. i cut the 2 tubes short squeezed them with a vice and welded them but i have heard they make plugs for that. dooh.
next thing is coilpack relocation alot simplier than i thought. 3 wires go to it on 1 side there is a 5pin connector(don't know exactly where it connects to) a 2 pin connector(connects to a sensor on the back side of the engine) and on the other side there is a 2 pin connector(1 wire is a ground and i don't know what the other is for)
all u really have to do is pull apart the main harness and seperate the 5 pin connector and the 2 pin connector where 1 of the wires is a ground, peel them back until they reach the coilpack, retape the main harness, reloom the main harness, loom your new wires and there u go. next the 2 pin connector that connects to the sensor on the back. just pull it out of it's original path and route it up to the coilpack.
next the heater core connections. one connection is blocked off on the waterpump as u might notice. just stick an 3/8 extension into it and unscrew the plug then use a 7/8 deepwell socket to unscrew the connector off of your original motor, reseal with some thread sealent and screw it in. as for the other side of the heater core just hook it to the connection that sticks out from the tb neck.
next is the tps sensor wiring. your wiring will be too short to reach the tps(at least mine was) so i spliced and soldered in 6 xtra inches.
next are sensors in general. they all look identical but i switched a large portion of them anyway. i switched the knock sensor, the fan switch(the one on the backside), the oil sending unit, the charcoal purge valve, and the o2 sensor. i left the following ones in place the sensor that screws into the lim, the sensor that screws into the cam bank, the sensor that screws into the front head, the crank position sensor, the tps, and the iac.
i will have updates on the sensor part after i finish hooking up the engine.
next is the egr the only hurdle i have ran into so far. i had a mock up of of adapting the old egr valve into the new system but after i put the engine into the car, the mock up doesn't work due to the egr valve sticking up too far so it is back to the drawing board on this. i will have updates on this too.
update i mocked it up a different way and it seems to fit(barely) so i am going to proceed with this design but if could do it over i would do it differently. cause the fitment is TIGHT!!! i will let u know if it works.
next is fuel lines, u will need the 96 lines that go from the rail to the quick connectors.
