wire short/my fault = fire
  • wire short/my fault = fire
    go to here.......http://www.w-body.com/forum/viewtopic.php?t=19550
    my other option aside from selling....taking the whole dash apart and seeing if anymore damage is done. i got those 2 yard z's to go to for parts. right now, i dunno
    http://www.w-body.com/forum/viewtopic.php?t=24111
    Car Domain site!
    13* cam timing, p&p\'d lower intake, tapered t.b, FFP chip, FFP mount and the 1st lumina w/HUD!!!
    That's why they invented the gromet.
    Lyle
      which got melted, it was the "lead" i had the wire connected to, to go through the firewall. 2 lessons learned; disconnect the +pole, and never use a hanger again but the good news is that it still starts/runs, and hud still works. i will most likely take it all apart to get back there, i know my radio wires are fried; no display or lighting from it(might be that i cut the power cable to it), speakers occasionally hum/crackle
      Car Domain site!
        thats no good, when you put it back together fuse everything!
        -Chris
        1992 Chevrolet Lumina Z34 3.4L TDC Getrag 284
        1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
        1997 Pontiac Bonneville SSE 3.8L v6, Hydramatic 4T60E
        1987 Chevrolet Camaro 5.0L v8, Hydramatic 700R4
          Man, that sucks. Who would have thought a hanger could let you down. But yeah, what he said fuse everything. Another good thing to do is run one large wire 10-8 guage (fused) through the fire wall then branch off from there inside the cab, using a small fuse block. Good luck.
          Lyle
            the dash is almost off, but there an U shaped bar inside the dash(upside down) that has 2 7mm screws, which are upside down and above the steering column. at the end of each side of the U, there are those "pop" plastic things(2 @ each end). those are a pita! the ones under the gauge cluster, by the 2 upside down 7mm screws, i had to cut their heads off and pop it down and out on the floor. so if anyone knows how to get the U disconnected from the dash, please tell! :P
            Car Domain site!
              heres the damage report!! clifford alarm brain, and the firewall gromet. the power cable for the subs is gone, freeing up some hella space, and i lost cliff.
              Car Domain site!
                jeebus! thats one fried alarm brain!
                -Chris
