what is the fuel pressure in these cars be4 it hits the fpr?
fuel pump output
The only pressure that is retained is on the inlet line going into the rail and incliding the rail, after the rail it goes back into the tank at less than 4-5 psi.
my fuel rail maintains a psi of 35...and around 50psi on the fuel inlet line.
If the return line has a kink or is plugged then pressures are directly affected coming in from the inlet.
On a full tank pressures can be slightly more.I am back
Mechanical/Service Technican
