RWD DOHC notes
  • #16
    You'd have to turn the lim to get the uim to flip around.
    I'd really like to have a RWD TDC car, but then why bother with that when the 2.3 Q4 can tuck in easier and make decent power with some power adder help.
    • #17
      sometimes it is not about how easy the job is because some people like a challenge. i think the swap would be cool just because the motor is different from the rest of the 60*s and it wasnt meant to go into a rwd car, but it has the same tranny bolt pattern. plus it seems like it hasnt been done.
      Firebird: The beta version
      • #18
        I have wondered if the 3.4 DOHC heads can be put on a RWD 3.4 block? 3.4 crate motors are available so surely you can obtain a block. I would like to put one in my S-10 Blazer 4X4.
        • #19
          No.... the pushrod blocks are different.
          And with a tubular k member you have a ton of room to slide the engine forward to make clearance. I actually moved mine back closer to the firewall than a stock v6.
