Hello everyone!
I know ahead of time that when I pose this problem, I'm several years late to the bandwagon here, but I would really like some of you to help me start this.
First, the problem is with my 1996 Pontiac Grand Prix GTP with a 3.4 liter V-6 I bought new in 1995 and she's been a great little car. The wife and I actually gave it to our son last year for his college transportation. She's got 140,353.12 on her right now....Practically every option available that year, so I've always tried to keep her up. Has ALWAYS turned over about half a turn and started RIGHT up, growling like a lion. I would say purring like a kitten, but it sounds a little throatier than that.
Well, after all these years of not having to open the hood except for normal maintenance, the actuator spring inside the timing belt actuator snapped the holding tang off inside the actuator, loosened the belt and it jumped time about 3 months ago.....just before the end of the school year. I know I should have changed the belt long ago, but I did frequently inspect my belt and it ALWAYS looked great. It actually looks good enough even now to put right back on the car, I swear, I'm not lying and could even show y'all, but since it had to come apart, all new stuff went back....of course. I started tearing into it about 4 weeks ago. The only reason I didn't finish the belt replacement and timing job 3 weeks ago, was IT NOW TAKES ABOUT 3 WEEKS to get parts for these engines anymore. I don't know if y'all have tried lately, but it took NAPA over 2 weeks and GM themselves don't even stock many of these parts anymore. I neeeded to replace one of the rings/collets that hold the cam sprocket and IT ain't here yet. I'm having to replace one of those because the rear cam sprocket bolt right next to the firewall......naturally.....rounded off and NOTHING I tried would get it. A grinder did. I scarred the surface of that ring a little working in just the 1 1/2" space back there and wanted to go ahead and replace that. The old one, I'm sure, is still fine, but I didn't know it would be that hard to get when I ordered it. It's on there right now and she's running perfectly fine, but I put the old ring on the second cam from the front and can get to it very easily when the ring gets here.
.......and I apologise for giving a little too much background here.
ANYWAY, night before last I fired her back up for the first time in a little over three months and she's back to her old self.....running wise. Everything installed, everything put back together, wires re-tied and everything completely cleaned. Looked very close to new under the hood again.
Today, it needed a new inspection sticker, so I backed her out and noticed a tennis ball sized oil spot. Ok, went ahead and drove it to the shop for the sticker. Smoke was whisking out by the passenger window (from underneath, of course) when I got to the inspection place, but MAYBE she's still burning off some of the major work drippings......I thought. Shop was a 8 miles from the house. 8 miles later, back at the house now, I've still got a little BIGGER whisp of smoke and I hear the old familiar sound of the power steering pump. Sure enough, fluid is low now (I topped all that off when I finished) and now there's a steady drip every 3 or 4 seconds under the car.....so I'm practically certain I fiddled TOO MUCH with those power steering lines while I was doing the timing, so whatever has happened here is my fault.......
BUT.....
How in the WORLD do I even get a peek at EITHER line in this thing???? I can't see down through the top and I can't see anything looking up from the bottom? I don't know which line it even is or where they go once they make that 90 degree bend at the firewall and disappear. I can't locate them from the top or bottom to check what I need to do and THEN, what do I do if I just want to go ahead and replace both lines because I can't even find them.
Have any of you good folks changed these power steering lines on a 1996 GTP before? What do I need to do to inspect them even???
Guys, I appreciate any tips here. All the money I saved on the timing job, I'm afraid is gonna go to some shop to replace these lines now.
Thanks for reading such a long post too,
Rob. (Eagle-1)
BUT.....
Rob. (Eagle-1)
