1993 Z34 Lumina.
About a month ago, I began noticing a bit of a noise coming from (I think) the r front wheel, with a corresponding "vibration" in the steering wheel. This is completely unnoticeable until reaching 60mph or higher and seems to change somewhat (almost disappears sometimes) with curves or slight movement of the steering wheel back and forth.
I have had the tires/wheels rotated/balanced, but there was no change in the symptoms. I also took the opportunity to inspect things when changing the front brakes last week. Nothing obvious was found.
I am thinking hub/wheel bearing..your thoughts?
Thanks.
Thanks.
