okay i dont know anything about this but i would like to learn. what i want to know what all is involved in switching either way, which is harder, and which is most worth while thanks
obd 1.5 to obd1 or 2 lq1
i went to OBDII. you can find a used DHP powrtuner for a few hundred bux and can calibrate just about anything you want.... supports '96 and '97 DOHC's.
you will need a 1996 DOHC ECU and engine harness if you have a LQ1 with a 4T60-E... if you have a MT then you can used a '96 or '97 setup... change like 5 wires on the C100 connector and add a OBDII data link port under the dash and boom your OBDII...
SShane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
DHPs go for about 325 used unless you get lucky. They pop up from time to time. I use HPT, but I do more than just 1 vehicle as well and there will support for the HPT since the company is still in business.
I still think OBD1 is easier to convert to for you but you might want to go OBD2 to retain the MAF since you want to get reground cams and potentially give yourself a rougher idle. MAP is great until you have no vacuum.Ben
Originally posted by Jake91 View Postwhat is involved with a obd1 swap?
Originally posted by Jake91 View Postreally thats all? i have a freind with a dhp so im set im definently going obd2 then just a question how long did it take you to do
I did have to add 1 knock sensor and change the other for the new harness but the rest of the sensors just worked (I had to disable the EGR, its not the same as the older ones), and swap my NSS connector from the old harness to the new OR use the new NSS (neutral safty switch, on trans).
Realisticly if you swap the pins over before the install, you should be able to do it all in a few hours 3-4 (with reasonable beer breaks between)... Alt wire was a bitch as was removing the rear knock sensor (stupid squeeze style connectors).
If you search for my OBDII swap threads there is a bunch of info... D.O.H.C. (mark) also did the swap.
SShane "RedZMonte"
