I currently have a 96 DOHC in my Fiero, I have had problems with a noisy lifter. My question is I can get a complete top end from a 97 DOHC, are the lifters in the 97 better than the earlier lifter?
You could go with the lighter 35mm tappets in Ben's store at WOT. 97 are 33mm and may offer a slight weight savings, but probably not as much as the one at WOT. At least with a 96 you can get any from a 91 all the way to 96. Other than the tappet size, the 97 setup is exactly like what your 96 is.
91 Black Lumina Z34-5 speed 92 Black Lumina Z34 5 speed (getting there, slowly... follow the progress here)
The thing you have to watch out with earlier cams is the ones with/without the Cam Position Sensor (if your ECM/PCM uses it). Otherwise, yes.
