I am looking into buying a complete factory long block DOHC and running it in an S10. Motor mounts are not an issue, I can fab them, the engine comes with a manual flywheel, I will use the 5 speed in the truck.
Here's where things change: I have 3 sets of Weber down draft carbs which I plan to fabricate an intake to bolt to the heads. I will have to fabricate headers which shouldn't be too difficult, and the kicker is going to be the ignition. Since there is no way to put a distributor on this engine, you know where the distributor hole is... I will have to have a crank fired ignition that does not use a factory computer (stand alone)
I've looked at alot of these motors, they aren't much different (space wise) than a 2.8 although the heads are mangous big. It should be almost a bolt in to an S10. The problems that will be a little tricky are the coolant outlet / inlet, which still shouldn't be too bad, everything else looks straight forward. I think the 2.8 oil pan even has the same mounting bolt pattern. I figure a set of well tuned Webers, headers and a good exhaust will most likely help this engine to 225HP.
Somewhere I read that these were originally 275 HP, but the cheesy 700 r4 couldn't be considered reliable so they detuned it to be less dangerous to the auto tranny. Effn cheap auto trannies.
