i just tore my z34 engine down to the block and was wondering if i could reuse my piston rings.i cleaned them up a little to check for cracks or any warping and they look good still.any help is appreciated thanx
old piston rings???
It would be best to get new ones, but I've seen old ones reused. Just be sure to at least hone the cylinders to give them something to bite back into and watch for oil consumption until they wear in again.-60v6's 2nd Jon M.
Originally posted by hypedz34 View PostI just tore my z34 engine down to the block and was wondering if I could reuse my piston rings. I cleaned them up a little to check for cracks or any warping and they still look good. Any help is appreciated. Thanx...
To compensate for this ever widening area, the piston rings are designed to expand into this wider area and this constant flexing in and out to go from wider at the top of each cylinder to being squeezed tighter at the bottom eventually fatigues the best of them. But as the engine ages and wears...so too does the ability of the rings to "spring back" and make a proper seal. Soon the engine oil invades the cylinder and begins to mix and burn with fuel and performance gradually dies as the oil in the crank case is infected and diluted by gasoline making its way under compression past those tired rings, making matters worse by thinning out the life's blood of engine oil and its ability to stave off engine wear. This is yet another reason to invest the time and money to have the engine block boiled out, and have the cylinders bored slightly larger to make them essentially straight again for the brand new piston(s) and ring set(s). Putting New Pistons and Rings in a Worn Block... is like putting a Fifty Dollar Saddle ...on a Two Dollar Horse.
The only thing these old rings are good for (and this must be done with gloved hands to avoid sharps injuries) is to break the solid edged rings into 2-3" curved lengths and lightly dragging these segments around the grooves of any re-usable piston sets to remove baked on carbon deposits that remain after their final cleaning... pulling only in one direction... with the broken edge trailing flat inside the grooves so as to avoid either scoring the aluminum areas in these valleys or damaging the adjacent lands and cracking them during this process.Last edited by 60dgrzbelow0; 03-19-2010, 02:46 PM.
All of this does depend on the current mileage and age of the rings though... Just remember that.
I've reused rings with 60k miles on them in my other 3400, and I'm reusing my current rings in my engine since they do not have that many miles on them and the cylinders are far from worn.
But on a higher mileage engine, I will agree with 60dgrzbelow0
