I suspect my car to have either a slow IAC or a minor vacuum leak that I'm having difficulty tracking down. All the intake gaskets and most of the vacuum lines are brand new. There is a T connection for vacuum hoses beneath the cruise control unit. One of the lines from this connection leads under the washerfluid tank before it goes out of sight, I didn't bother following it any further but I'm assuming it goes to the vacuum ball. I pulled this line out of the T connector and put a piece of vacuum hose on it. Using lung power I sucked on the line and I could hear it 'inhaling' air or if I blew through the line I could hear air pushing out. It was as if nothing was on the end of the line because there was very little resistance. Is this normal? Or have I found a leak? Seems to me if this was connected to the vacuum ball this line should be air tight, how else could it possible retain vacuum? Does the vacuum ball just have one line running to it or is there more than one?
Note: All vacuum operated devices (hvac, cruise control, etc) function normally. Once the car is at a full stop it take a bit longer than usual to return to idle speed. It hovers around 1200 rpm on the tach for 5 seconds or so then drops to the 1000 mark. I realize this could be tach error, but other times it drops to what appears to be 800-900 rpm and when it does so it sounds more like a lower idle. From traffic light to traffic light it won't hit the 800-900 rpm. Usually it settles somewhere between 1000-1200 rpm but if I let it idle for a minute or two it seems to find its way down to a lower idle.
Thanks
Thanks
