I have 91-95 LIM gaskets laying around.. Do they fit the 96-97 by a chance? i dont want to buy extras if i dont have to and can use these..
LIM gaskets
LIM gaskets
Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
Drilled/Slotted Rotors
White
3" Magnaflow Catback
90 Pontiac Turbo Grand Prix
5 Speed Swapped
127,000
Spec Stage 3 Clutch
230,000 mile Getrag 282
Emissions Deleted
Brand new Engine 1,000 Miles
Fully Custom Built carTags: None
I've been told the 96/97 gaskets are thinner then the 91/95 gaskets (sounds like a much better design), so I would have to say no.-60v6's 2nd Jon M.
from what i understand, no. i got the oem gaskets WAY cheaper then felpro.. felpro '96 gaskets are like $70-80. OEM are like $35Shane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
hmm thats wierd.. i compared the 91-95 gasket to my spare 96 LIM and my 95 LIM and it all lined up but the thickness i have not checked.. but i am going to the dealer to get them if they r cheaper..Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
Originally posted by 94GPGTP View Posthmm thats wierd.. i compared the 91-95 gasket to my spare 96 LIM and my 95 LIM and it all lined up but the thickness i have not checked.. but i am going to the dealer to get them if they r cheaper..
Originally posted by bve32k View PostI am not sure about the LIM gaskets..I am almost positive they are cheaper at the dealer. I do have the part #'s for the UIM gasket and the throttle arm gasket that goes between the UIM and the throttle arm.Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
Ut Oh.. on gmpartsdirect and its showing the timing belt is only for 91-95 and 96-97.. is that true or all the belts the same?Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
The 96-97 belt has rounded teeth, the 91-95 has square. 96-97 belts should run cooler with that said.-60v6's 2nd Jon M.
hmm ill have to check to see what that spare belt i have fits.. I know it was like to long when i tried it on my 94 gtp and my 95.. maybe its a 96 belt idk..Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
Originally posted by 1988GTU View PostCant the new belt be used IF you swap all cogs, the tensioner, and idler?Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
It should, yes. I was going to grab the cogs off of the engine in the yard I got my 96 style heads off of, but had no way to pull the intermediate shaft cog with the engine being in the car stillI do believe the idler and tensioner pulleys are all the same, though.
