I was wondering what exactly is a CAI and hoe does it work???And wich is better a CAI or your average cold air intake with a cone at the end.Also how exactly would you go about installing a CAI??any help is appreciated??THANX
CAI or cold air intake???
Most ebay CAI are just a filter on a short pipe in the hot engine bay. That's more like a hot air intake and will actually hurt overall power compared to most stock air boxes since you'll suck so much hot air in.
A real CAI/FWI locates the filter outside of the engine bay where it gets cold air, and also has a cone which has more surface area than an air air box with a small snorkel. Maybe 4hp at the wheels on average depending on engine.sigpicNew 2010 project (click image)
In my car there is a 3" hole by the battery, run the intake pipe in there, and unbolt the splash shield in the wheel well to install the filter on to that, then put back the splash shield.sigpicNew 2010 project (click image)
In my car there is space behind the splash guard between the inner fender/body. Depends on the car.
Pic without splash shield installed:
No modifications there. There is empty room behind the splash shield.
When I do mine I will use a different shaped filter, and mount it a little higher than you see in that pic, to keep it cleaner and out of water.sigpicNew 2010 project (click image)
A FWCAI is better than the plain jane CAI sitting next or infront of the battery.
What do you want more of? Money in your pocket or more performance in your car.
A wai is just for space and looks.Lifting my front wheels, one jack at a time.
I cut a large portion from the bottom of my airbox out because I didn't like the size of the little snorkel that went behind the headlight. It really is cut out more then I should have done, as I'm sure I'm getting some of the warm air from the engine bay, but not near as much as a WAI. I've gotten comments on my "exhaust" when I've wound it out too, but it was funny telling them "My exhaust is stock style, just replaced with mandrel bent 2 1/4. That wasn't my exhaust you heard." I probably didn't gain anything, but I wouldn't ever put a stock air box in it's place and loose that sound.-60v6's 2nd Jon M.
Originally posted by pocket-rocket View PostI cut a large portion from the bottom of my airbox out because I didn't like the size of the little snorkel that went behind the headlight. It really is cut out more then I should have done, as I'm sure I'm getting some of the warm air from the engine bay, but not near as much as a WAI. I've gotten comments on my "exhaust" when I've wound it out too, but it was funny telling them "My exhaust is stock style, just replaced with mandrel bent 2 1/4. That wasn't my exhaust you heard." I probably didn't gain anything, but I wouldn't ever put a stock air box in it's place and loose that sound.
I hacked off about half of mine. I went from mounting point to mounting point, then strait up the sides and just under the sealing flange for the filter element, and that whole front piece came off which is why I said it probably still gets some of the heat from the compartment. I should snap a pic of it one day....-60v6's 2nd Jon M.
since when are is a fender mounted CAI called fmcai? lol. if its outside of the engine bay its a cool air intake imo. who cares where it is as long its the most convient place for it
mine goes down in front of the radiator by the slave cylinder, under the battery and through a factory hole and around the inside of the bumper to infront of the radiator. kinda a pain but its the only place i could run it without cutting the bodysigpic
