alright, here's my story... I have a 95 Z34 About 3 months ago I was driving home from school going down a hill and the car shut off on me. Luckily I was able to get it to the side of the road, anywho... I tried starting the car and it would just crank and crank with no fire, all the electronics worked so i figured it wasn't electrical. I know some about cars and figured it was the fuel pump. Along with the fuel pump I had that distributor oil leak thing that needed some long overdue attention, I decided to also tackle this to get rid of little puddles of oil in my driveway. After replacing the oring and seeling it up, I installed new lim gaskets and uim gaskets, fuel injector orings, valve cover gaskets, both egr gaskets, replaced the booster hose, replaced iac, starter, and replaced pcv valve. I start it for the first time and get an idle around 2700-3000rpms. I only let the car run for about a min, as I thought it was unsafe to let the car idle like this. I also put it in drive and reverse and the idle dropped, but the car still felt like it wanted to take off and the idle was still unusually high. The idle seems the highest in park and neutral. I've read other posts and it sounds like I have a vacuum leak, but where? Am I missing something? I just replaced all the gaskets on this thing. Sorry for the length, any help is greatly appreciated
-Martin
-Martin
