anyone know if you can change the oil pan gasket in this year without taking out the motor? If so how many hours could it take?
Oil pan gasket 91' Z34
pan gasket
Drop the subframe and you can take the pan off. You'll still have to support the engine with a support or a cherry picker.
It's also a good time to replace the lower engine mount. They're pretty cheap so might as well do it while you have the subframe out, especially change it if oil has gotten it.Jesse M.
3x 1990 Turbo Grand Prix
1987 Monte Carlo SS Aerocoupe
You will also have to get it aligned after removing the subframe since it won't go back into the same exact position it came out in. But yeah, support the engine and drop the subframe.-60v6's 2nd Jon M.
