Car runs like crap
  • #31
    Ok here is what I scanned when I was ideling at a red light
    LOAD VALUE- 4.3%
    COOLANT TEMP-181 *F
    SHORT TERM FUEL TRIM- 6.2%
    LONG TERM FUEL TRIM- 16.4%
    MAP SENSOR-14 IN.HG
    ENGINE RPM- 765
    SPEED-0MPH
    IGNITION TIMING- ADV -19.5*
    INTAKE AIR TEMP- 123*
    AIR FLOW RATE- .81 LB/MIN
    THROTTLE POSITION- 0%
    2ND AIR STATUS ATMOSPHERE- OFF
    OXYGEN SENSOR 1 BANK 1- .590V
    SHORT TERM FUEL TRIM1- 3%
    OXYGEN SENSOR 2 BANK1- .445V
    SHORT TERM TRIM- NOT SUPPORTED
    OBD II REQUIRED- (CARB)
    FUEL SYSTEM 1- CLOSED LOOP
    FUEL SYSTEM 2- NOT SUPPORTED
    I have (2) short trim fuels, not sure why, but thats straight from the scanner.
    M
    • #32
      My IGN ADV is -30 @ idle. I dunno if it is supposed to be that high, but the car runs great now!
      I ended up re-timing the engine and now it has acceleration like it use too!
      • #33
        its not negative timing.
        • #34
          Good To Hear... So Your Problem Is Solved??
          Robert
          New Rebuilt 3100
          New Rebuilt 4T60-E
          Exhaust
          Drilled/Slotted Rotors
          White
          3" Magnaflow Catback
          90 Pontiac Turbo Grand Prix
          5 Speed Swapped
          127,000
          Spec Stage 3 Clutch
          230,000 mile Getrag 282
          Emissions Deleted
          Brand new Engine 1,000 Miles
          Fully Custom Built car
          • #35
            • #36
              Originally posted by d.o.h.c View Post
              Car has great acceleration now! So I think it is all good now! I am just getting a Injector Circuit Control SES now. Not sure what it is though!
              • #37
                lol @ bumper nutz
                • #38
                  So I was right then? Your timing was off?
                  • #39
                    Yes, cam timing was off. I don't know why the ignition timing keeps coming up.
