Guys....first, a MAJOR thanks to this list and all the advice I got from it. Hopefully I have been able to help others (or will) as much as I have been. Sappy, 3100MPFI, Chris GP, etc.....all are called out for special thanks!
Anyhow, here are the final (hopefully) results from my 3400 DOHC swap. A quick refresher....
I have a 1995 Lumina that had a 3100/4T60E combo. At 285K miles, the cam snapped in half due to trashed cam bearings. I used Mobil1 since I got the car, and other than the cam bearings.....she was immaculate. WHile I could have easily replaced this engine with a 3400 I had laying around, the 3.4 DOHC was a much more intrigueing choice. The engine/harness/PCM I had was for a 1996, so I assumed I would be able to reuse my current trans and such. I could have....but.....I could not find a tuner package for a 96 computer, but I could for the 97. So, I changed the year to a 97
New harness and PCM took care of that issue....but now I had to swap a 4T65E in, as that is the trans in the 3.4 DOHC cars of that year.
For the engine, I replaced all the timing components hoses, belts, accesories, plugs, wires, etc..... I used Mobil1 in the engine, synthetic PS fluid, and Dexron VI inthe trans. I also installed a spacer shift kit in the trans.
My first attempt to fire it up resulted in it running.....like a big turd. Major miss, running rich, etc. After a bit, it wouldn't even run. It would always start fine, run for about 2seconds, start stumbling....and die. I checnged out the fuel rail/injectors for a brand new set....no luck. After going through all the diagnostics.....I narrowed it down to a bad PCM. Popped in the 96 I had laying around, and it ran great. Sooo.....I ordred a new 97 computer, which took 2 weeks to show up (grrr....). HOWEVER, in the meantime.....I also found that the front cover had a crack inthe coolant passage. Off came the timing belt (in the car!) and I JB Welded it up. So far.....so good... I am running some stop leak in the coolant as well, so hopefully this is good enough. I did have to shim one of the idler puleys in the timing setup though to clear the repair.....so far so good there too. Timing belt is running about 1/8" from the end of the cam pulley....so I'm good. I now have a replacement cover which I recently beadblasted and clearcoated......so when I get inspired, I am going to put it on. What a PAIN!
Anyhow, once the new PCM showed up (last Friday), I plugged it in, started it up...and brought it up to temperature. Wow! That thing sounds nice! I checked all the fluids, for leaks, and all that.....and it was good. Drove it in and out of the driveway/garage, around the block, around the city a bit more, then around a loop that included highway. ALL is good!! WooHoo!!! So, this Sunday, I took my first long drive....to my P's for mothers day. Made it there no problem, but I popped the hood to make sure everything was looking good....and I noticed the main harness off the C100 connector had moved and was rubbing against the P/S pulley! Doh! The loom was worn through, and a couple of wires had copper showing as the insulation had worn down. I don't know how it didn't short out....but it didn't. I moved the harness over, and repaired it when I got home last night. All is good....
Now, I just need to figure out a way to get the damn rear O2 to start sending usable data to the PCM to put the MIL ight to rest once and for all. I tried the doubled up anti-foul thing, and now am down to one anti-fouler and I am still getting a non-repsonsive O2 reading P code. I am going to ditch the antifoul thing tonight and see about running it right in the exhaust stream.....but I think that may be too much and I'll get it TOO responsive. Once I get the tuner software, I am just going to shut the damn thing off....unless I pop for a new converter
Drove it to work today with no issues at all. Runs nice and smooth....
My comments on this motor are:
- Idles smooth as silk. I could almost balance a house of cards on this thing while it is running and have no problems.
- Top end....pulls like a bat out of hell! Seriously, from 60-90 goes by fast!
- Conversely, bottom end feels marginally better than my old 3100. I can spin the tires from a 5mph roll though....so it defainitely has more power.
- TBD as far as mileage goes. I have been on the throttle a lot more than I normally would be, so I tend to think this tank willbe my worst case scenario. Has to be better than the 17mpg avg in my Trailblazer though
- My stock downpipe is 2 1/2" and I have it neck down to 2.25" and then 2" to mate to the stock rear exhaust system (seriously.....2") I think this may be a bit restrictive (even with no Cat) as I hear a "wooshing" sound over say 4000rpm. Sounds like a restricted exhaust
So, so far initial (200miles or so) reaction is good. I like this motor.....but it was a LOT more work than I thought it would be. Granted, I wanted to do this all factory....and not rig antyhing, so I had a lot of changeover to do. Simple things like even heater hoses, trans dipsticks, etc all needed to be changed, in addition to things like a unique driver side halfshaft, rewire, and of course the engine/trans.
Any suggestions as to a decent, inexpensive (ie not Borla) exhaust for this car that is halfway decent? I think a full 2.5" system would work best.....
Again, if anyone has any questions about any part of this, let me know. MUCH thanks to everyone again!!!
Larry
Larry
