I finally got that twin cam running. It is not perfect, but it is not too bad. I will have to iron out a few bugs. Here is what all is still left to do.
ENGINE:
I have a MASSIVE tranny leak. One of my metal tranny lines where the metal line is crimped to the rubber hose, the crimp is messed up. I will cut it off tomorrow, and put a hose clamp on it. The power steering pump is making noise, but I think it might just be air in the system. I will give it a few days to work the air out and see if the noise goes away. The power steering seems to work fine otherwise.
EXTERIOR:
I need to replace the rear 2 wheels, and tighten all the lug nuts. One of the tires has a nail in it (damnit Jay), so I will do a flat repair on it as well. I also need to put the HOOD on the car. I remove the hood whenever I am doing a lot of work to the engine so that I am not constantly bent over. It really helps my back. I also need to give the car a good waxing. I have never done it, and it probably needs it. One of the foglights is out. The houseing is cracked, and everything. I think I am going to do something custom with them. Also, the passenger side front turn signal (center of the car) is messed up. It is tilted upwards. Tomorrow I will pull it apart and see what is going on in there.
INTERIOR:
I need to reinstall the knee bolster on the steering column. I also need to make a cover for the HUD, but that can wait until later. I lost the clip that holds the shifter knob in. I need to find one, and get it in there.
Once the car was running, the only dash lights I am getting is for LOW OIL LEVEL, and ABS. I don't know what is going on with the ABS. I do know that I could not find one of my wheel speed sensors, so I stuck a different one on there. It is possible that the one I put on there is bad. Before I go and start second guessing myself, I am going to get the car scanned, and try to fix it. I tested the automatic headlights (which I added in), and they work fine, but it was too dark to test the DRL's.
On to the PICS
First the interior. This is the cluster with the car running. There is only 4 idiot lights on. They are FASTEN SEATBELTS, ABS, BRAKE, and LOW OIL LEVEL.
![](http://i174.photobucket.com/albums/w86/riven2129/green/running1.jpg)
This is the radio on. It is a BOSE radio with BOSE speakers and BOSE amp. It works really well, but for some reason, when you first turn it on, it has a feedback. I think that is because I am using the newer BOSE radio with the older BOSE amp.
![](http://i174.photobucket.com/albums/w86/riven2129/green/radioon1-1.jpg)
Here is the engine fully assembled.
![](http://i174.photobucket.com/albums/w86/riven2129/green/finished1.jpg)
Another pic of the engine finished. All I have to do to the exterior at this point is replace the rear wheels with the newer ones, and put the hood back on the car. Then it will be ready for a road test (after I fix the tranny fluid leak that is).
![](http://i174.photobucket.com/albums/w86/riven2129/green/finished2.jpg)
Lastly, here is 2 video's. They are both of the car running. One is interior and one is exterior. I still have some minor work to do to smooth it out, but this is a HUGH step for progress.
![](http://i174.photobucket.com/albums/w86/riven2129/video/th_twincamrunning1.jpg)
ENGINE:
EXTERIOR:
INTERIOR:
On to the PICS
![](http://i174.photobucket.com/albums/w86/riven2129/video/th_twincamrunning2.jpg)
