Does anyone have a source for .020" rings for the 3.4TDC? I have .020" Silvolite pistons but I need the rings that go with them. Summit has to special order them and they're $125 for the set!! Sizes are 0.5, 0.5, and 4.0. Thanks all.
.020 rings??
After calling around and hearing between $110 and $125 from several people I called a place in Texas that has them for $59.00. They can be found at www.newengineparts.com . They build short and long blocks so they get parts at quantity discount pricing. Hastings # was E-548K-020. I picked up an oil pump for $62.00 and a complete engine gasket set for $125.00. Last year I bought a reman crank from them for $222.00 that included a $100 core so it ended up costing only $125 with bearings.85 Fiero GT 3.4TDC w/5-speed in progress
Wow, prices aren't bad. What brand of gaskets were the set? Our local Advance store gets just the head gasket set from Felpro for $118.-60v6's 2nd Jon M.
I got all of the parts I ordered today. They all seem to be of good quality. The rings are Hastings Moly rings (Made in USA), the oil pump and pickup are Melling (made in USA), and the gasket set is Corteco (Made in USA, Canada, Japan, Spain, and Taiwan) and contains the following:
2 head gasket
6 exhaust manifold
Water outlet
1 plenum gasket
6 spark plug tube seals
2 camshaft housing
5 intermediate shaft seal
1 timing cover
1 O ring
1 oil pan drain plug washer
1 water pump
2 O ring
2 valve cover
2 intake manifold
1 oil manifold
12 fuel injector seal
1 O ring
2 camshaft rear cover
1 oil pan gasket
1 timing cover seal
1 oil gallery tube seal
1 oil cooler
Now I just hope the wife'll give me some time to play with my new toys...85 Fiero GT 3.4TDC w/5-speed in progress
