I'm having an annoying problem w/ my GP. The CGL started coming on when the alternator took a puke, but it is still coming on after I replaced the alternator. It comes on for a few minutes then off for a few and then back on and so on. The volt meter never drops below 13 volts. It actually reads higher all the time, but supposedly the CGL shouldn't come on due to low voltage unless its under 13.0. None of the other gauges malfunction, either, except the low fuel light will be on for less than a minute after you start the car, but will go off.
I think these other problems are also tied in. The courtesy fuse (for the map lights, etc.) blows a few seconds after I put a new one in and my power door locks quit working from the switch (key fob works fine, e-windows work). It's got to be a wire, right? Where would you start looking for the problem and are they all related?
Please help
Please help
