i have 93 cutlas conv. with a DOHC. it has the 4t60e in it. i wanto change it to a 5 speed and wondering about if i have to change any harness or what to do with the tranny plug
tranny swap
If you reuse the auto harness you gotta:
-lengthen the VSS wires
-jumper the starter wire across the range switch plug
-if you want the reverse lights and trunk release to work you have to wire them in
Other then that you leave the 2 tranny plugs just laying there.
thanks for the help but could you tell me what wire colors to connect or cut and what vss means. i got all the parts from a 89 GP, shifter ,cables,pedals ,master/slave assembly. don,t have a tranny yet but will probably go with a 282 is there any thing else i needand also where can i find a flywheel for the 3.4 that isn,t to pricey
that is right the cutlass convert never came with a 5 speed1994 Cutlass Supreme Convertible 3.4 DOHC
1969 Oldsmobile 442
1997 Chevy Tahoe
http://members.cardomain.com/mperkins442
Originally posted by nickheadthanks for the help but could you tell me what wire colors to connect or cut and what vss means. i got all the parts from a 89 GP, shifter ,cables,pedals ,master/slave assembly. don,t have a tranny yet but will probably go with a 282 is there any thing else i needand also where can i find a flywheel for the 3.4 that isn,t to pricey
With the 282 tranny, be sure to get a performance clutch as the stock one WILL NOT hold. The flywheel can come off any internally balanced 60v6 motor, I think its 88+
Why would the gearing be strange? I find the 3.61 to be just fine (I've driven it on a Pushrod, and a Quad4, but not a 3.4 DOHC)
With the 282 and 3.61 gears you should easily hit 70 MPH in 2nd gear!
That 3.94 gearing is only in 91 W41 cars, and in 92-94 Quad4 HO cars.
Cliff Scott
89 BerettaGT
89 Volvo740Cliff Scott
89 BerettaGT
04 AleroGX
Originally posted by Cliff8928With the 282 and 3.61 gears you should easily hit 70 MPH in 2nd gear!
There is a reason that the 284 was engineered with ratios to where at 7000 rpm in 2nd gear you're at 60mph.The 3.4 has a sorry low end, now if you're 2nd gear goes to 70, you're first will be around 40. By having it at 35, you get into the powerband faster, adn the shift into 2nd will drop you less rpm that with the 4--70 shift.
I do not think you're ready to do a tranny swap, nor do you know why you are doing it. If you are doing it to be able to shift yourself, than fine. If you are doing it for performance, the 70mph 2nd gear won'te do anything, except allow for slightly better launches becuz you have a clutch to play with.
You can also use the MR3 or MK7 Izusu tranny. Toe MK7 is the newest one. I heve it im my Fiero and its holding very well. And my engine inst stock. Here is a list of the cars that have them
Isuzu MR3/MK7 5 Speed (FWD) Manual Transmission Parts
These quality manual transmission parts and rebuild parts kits are designed to be top of the line overhaul kits. We have include information on how to identify individual transmissions, application information, model year,and detailed kit and part availablity by transmission type. Isuzu transmissions are covered in this section; MR3/MK7's, front wheel drive (RWD), typically used in Buick, Cadillac, Chevrolet, GEO, Isuzu, Oldsmobile and Pontiac requiring 5 speed applications.
Different overhaul kits are available depending on the extent of the overhaul that you plan, the contents of the kits are described as follows:
Paper Kit: Gaskets & Seals. If there are no gaskets for a particular transmission, no kit will be available
Bearing Kit (FWD): Main bearings and seals only. No differential carrier bearings or nuts.
MRK (FWD): Main case bearings, differential carrier bearings, nuts and small parts as they are available.
Information and parts are provided for the following Transmissions: Isuzu MR3/MK7 5 Speed (FWD)
IDENTIFICATION Aluminum 2- piece case with a 7 bolt aluminum rear cover over the 5th gear set. All of the main bearings are tapered. In mid-1988 the 1st/2nd synchros became a 3-piece design.
Buick
Skyhawk 1983-89
Skylark 1985-87
Somerset 1985-87
Cadillac Cimarron 1983-88
Chevrolet
Beretta 2.0L & 2.2L 4 Cylinder 1987-96
Cavalier 4 Cylinder 1983-86
Corsica 2.0L & 2.2L 4 Cylinder 1987-96
Geo
Spectrum 1985-88
Storm 1990-93
Isuzu
I-Mark 1985-90
Impulse 1990-92
Stylus 1991-93
Oldsmobile
Achieva except Quad-4 1992-96
Calais 2.5L 4 Cylinder 1985-91
Firenza 1983-88
Pontiac
Fiero 4 Cylinder 1985-88
Grand Am except Quad-4 1985-88
J2000 1983-84
Sunbird non-Turbo 4 Cylinder 1984-94
Sunfire 1995-96
Hope Helps
DreX
