Next best sparkplug?
  • #16
    The stock GM ignition systems run too hot (too high of Millijoules )
    This is the same in the newer Honda's and others higher mJ OEM ignition systems.
    This was something that many suppliers were alerted to, what happens is after not many miles the center fine electrode burns down into the surrounding ceramic insulator cone.
    What was recommended is to ONLY install them in the vehicles that have them equiped from new, so in other words a OEM application.
    1991 Grand Prix STE
    3.4 DOHC
    1 of 792 Produced
    Extensive Mods Done
    1991 Lumina Z34
    3.4 DOHC
    Getrag 284 5spd
    1 of 30
    • #17
      Good to know, thanks. I probably would have ended up using them again.
      • #18
        Yep..
        I put a set in a friends 2.8 Cavalier by his request and they lasted for a few months before it developed a missfire, same with the AC Delco Rapidfires. Ended up using Champions ($.90 ea) and they worked for another 20K till we scrapped the car.
        IIRC it also has something to do with the waste spark system..
        • #19
          the main reason why GM went to double tipped platinums?
          Andy
          fastest 1/8: 10.19@ 67.17
          fastest 1/4: 16.16@ 82.70
          • #20
            what about the iridiums? I have heard people having no issues with them in a 60V6.
            Anyone here try these Iridiums?
            I dont know what this means but "ASS HATS" is funny
            • #21
              i have the Denso U-groove Iridums. no issues. shouldn't...they are harder and have a higher melting point than platinums.
              Andy
              • #22
                There is NOTHING WRONG with OTHER platinum OR iridium plugs
                It is JUST THE BOSCH PLATINUM PLUGS because of there tip design. No other company makes them with a high ceramic cone covering the fine tip.
                I haven't had any problem with other platinium style plugs EXCEPT when the vehicle RUNS RICH OR FLOODS, then the fine tip platinum AND iridium plugs both miss fire like crazy where the regular style plug will still miss fire but NOT NEARLY AS BAD.
                If you are running AC platinum or iridium plugs JUST make sure your engine is running fine and they'll work good.
                Use them IN THE APPLICATIONS THAT CALL FOR THEM THOUGH.
                1991 Grand Prix STE
                3.4 DOHC
                1 of 792 Produced
                Extensive Mods Done
                1991 Lumina Z34
                3.4 DOHC
                Getrag 284 5spd
                1 of 30
                • #23
                  The A/C plug for the 3.4 dohc is ACR42LTSM
                  So this is a copper core plug??
                  • #24
                    yes.
                    i tried NGK iridiums but didnt have them in for long. it was around the time i was having problems w/ my magnecor wires. i cant remember why i took them out or how long i had them in there. i had a set of Pt rapid-fires and one of them went bad, but it couldve been due to the wire. now, i just run the R42's mentioned before.
                    91 GTP HM-284 GONE
                    96 Special Edition LQ1/4T60E GONE
                    98 Spawn of Satan (L67 Regal)
                    87 V10 SM-465/Mild 350
                    06 Cobalt SS/SC GONE
                    • #25
                      Originally posted by pwmin View Post
                      yes.
                      Thank you that is what I wanted to hear. As I start my wires next week.
                      • #26
                        i'm sorry, but what part of that did you want to hear? imo, its a waste of time and money to try anything but regular coppers in these cars, esp if you have to keep swapping plugs out on a car w/ 96-97 upper plenum.
                        91 GTP HM-284 GONE
                        • #27
                          about the coppers.
