Ok. I am going to try to explain this the best as I can.
My car under a load will sputter. When I hit the gas it will start jumping around. Usually only around speeds higher than 30. It does do it though sometimes in the lower speeds.
But I put some higher unleaded octane into see if it would help it any and it did seem to go away a little bit. Wasn't there as much but once I had to fill back up it started again.
Yesterday it was backfiring while I was driving. The backfire is not frequent. Only happens randomly. I tried to re-create the seen on video, but it would not do it anymore. It did not backfire at all today.
This sputtering is very noticeable in OD/TCC lock up. I tested the coil resistance and they came out to 6.47, 6.40 and 6.33.
