I'm finally getting to the end of my install into a 1988 5-speed Fiero. This is a California car, so it needs a functioning AIR system. Having never seen a 5-speed W-body, I have a question about a vacuum hookup.
The air diverter valve uses vacuum to pull the valve open. Can someone tell me where the vacuum is taken from on the motor? That is, is it ported (vapor canister or PCV line) or full time (MAP sensor or fuel pressure line) vacuum.
Thanks for any help you can give me.
