Starter Problems On My 94 GTP Maybe Wiring Issues?
  • Starter Problems On My 94 GTP Maybe Wiring Issues?
    I am having some problems with my GTP. When i start it up for the first time (cold) it kinda lopes starts slow. Then when i get it to normal operating temperature and shut it down and go to restart it up (hot), it starts like the battery is dead. It lopes really hard and turns over slow.. I have changed the starter to a newer mini starter and it does the same thing with the old one and newer one. Also i am having problems with wiring, i think? The dash lights dont light up, the sound from the radio cuts out when door opens or closes,and now im believing that there is wiring issues with the starter. Oh and i have also remember when i put the negative cable on it has a little spark when it makes contact.
    It would be great if anyone can help me out.. Thanks in advance!
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
    probably a ground problem. i would upgrade the charging and ground wires, but have the battery and alternator tested at auto zone or something.
    91 GTP HM-284 GONE
    96 Special Edition LQ1/4T60E GONE
    98 Spawn of Satan (L67 Regal)
    87 V10 SM-465/Mild 350
    06 Cobalt SS/SC GONE
      what do you mean by upgrading? I had autozone check the starter and alternator before i installed them on the motor before the motor was put in. I have a optima in it for now that has 780 C.C. i also have 2 autozone batterys that do the same. I did put a new rebuilt motor in the car. Possiblity the timing is a hair off?
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      White
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      Emissions Deleted
        does anyone who has been looking at this have any input?
        Robert
        New Rebuilt 3100
        New Rebuilt 4T60-E
        Exhaust
        White
        5 Speed Swapped
        127,000
        Spec Stage 3 Clutch
        Emissions Deleted
          I'd go through and check all of your ground wires, especially if this started after the new engine.
            Well today i cleaned all the ground wires that go to the transmission. 4 small wires and 1 big one that comes off the battery. while i was at it i cleaned the core support one and the actual battery connector the one on the battery. i also cleaned the postivie aux terminal,and the postivie terminal on the pass fender. still the same result slow cranking.
            Robert
            New Rebuilt 3100
            New Rebuilt 4T60-E
            Exhaust
            White
            5 Speed Swapped
            127,000
            Spec Stage 3 Clutch
            Emissions Deleted
              try a different battery. Optima is not really that good of a battery. Stick a 78 series in there and see if that does it. Another way to find out is have someone park next to you and hook up jumper cables like you are going to jump your car and see if the added boost helps you out. If it does, then replace the POS optima with something better.
              I feel I have a right to call optima POS after I had one EXPLODE in my car.
              Taylor
              1998 Lincoln Mark VIII
                check your timing. You might be off a hair.
                Lorenzo
                  Not to hijack, but what do you mean by that? I've had my Red Top for 5 years now. Every winter it gets deep discharged and every spring it fills right back up with power and gets back to work. I've used it to start a school bus that normally needs 2 batteries.
                    I had a red top many years ago that went bad after a few months. More recently, I had a yellow top in the Beretta. It sat for ~6 months, and it was completely dead when I tried to start it. Made several attempts to charge it (slow trickle charge, fast charge, and "jump-start" charge) and could never get it to work again.
                      besides the optima battery being used. I have another battery in it now, and it will do the same thing... slow cranking.. I hooked up our battery charger to it and put it on booster and it still did the same thing.. same with jumping off another car.. Would anyone know if fuseable links can cause this? Like if they were just about to go? Its the only thing i can think of.. thanks guys
                      Robert
                      New Rebuilt 3100
                      New Rebuilt 4T60-E
                      Exhaust
                      White
                      5 Speed Swapped
                      127,000
                      Spec Stage 3 Clutch
                      Emissions Deleted
                        Videos of the Problem IM Having
                        Sorry guys but i cant get the videos attached for some reason so you are going to have to copy and paste the addresses in your browser to watch these videos.. Please reply adn let me know what you think anything at all.. thanks guys.
                        Heres the First vid of the problems:
                        Heres the Second vid of the belt chatter i am having a clearer sound!!
                        Thanks guys in advance.
                        Robert
                        New Rebuilt 3100
                        New Rebuilt 4T60-E
                        Exhaust
                        White
                        5 Speed Swapped
                        127,000
                        Spec Stage 3 Clutch
                        Emissions Deleted
                          Problem FIXED!!!
                          Well guys heres what the problem was. Timing was wrong.... the front cam carrier was 180* off.. retimed the car and it runs awesome.. sounds alot like a 3.4 should.. Drove it and it drove 100 times better.. no slow cranking, no belt chatter, no wierd noises, nothing wrong with it now... yay!!! Just a quick ? for anyone... how many miles until my motor will be broken in? its freshly rebuilt.. i have 100 miles on it now.. thanks
                          Robert
                          New Rebuilt 3100
                          New Rebuilt 4T60-E
                          Exhaust
                          White
                          5 Speed Swapped
                          127,000
                          Spec Stage 3 Clutch
                          Emissions Deleted
