Cam timing
  • Cam timing
    Just a double check - on the 3.4l dohc - when timing the cams using a degree wheel on the crank I need to DOUBLE the degree readings, yes? As an example if I want 7 degrees retard for intake I need to go past TDC on the crank by 14 degrees before I lock down the cam, correct?
    Thanks - I'm doing the job tomorrow. By the way - stock block, heads, cams, heavy modification of airflow through the intake (redesigned intake), Corvette throttle body, tuned custom headers (2.75"), additional custom chip - dyno's at 228 to the wheels @ just over 6,000. Place that in a 2000 lb car (Fiero - heavily modified suspension) with an Achieva close ratio box and it scoots nicely.......
    Retiming cams in my backup long block because it "all blowed up" at Pocono 2 weeks ago (after 3 seasons). Big time. One entire junk long block. Even the mount for the timing chain to camshaft belt pulley was bent down several degrees from the "rapid motor decceleration" (6000 rpm ==> 0 rpm instantly). The timing belt was jammed between the pulley and the front motor cover.
    Dana
    sweet(not the engine failure) let's see some pix. and yes you are correct on the timing.
