96 3.4L Heads Torq Specs
  • 96 3.4L Heads Torq Specs
    I looked at the torq specs in the PDF and it says 44 ft lbs + 90 degrees. The Chilton I have says 33 ft lbs + 90 degrees. Which one is right?
    I know a few people on here have taken there heads off before.
    its 44 ft.lbs + 90*, i just checked GM Service Information
    Jake
      Thanks. I also had Travis check On Demand 07 and it said 44 ft lbs + 90 degree's. Thanks for letting me know!
