I have a 96 DOHC I am building as you all know. I am buying a Cutty vert w/ a Turbo setup.. I intend to keep the vert stock for driving around in the summer and such.. If I remember correctly, the 91-5 LQ1s have a lower compression ratio thant the 96-7.. I have my 96 heads and intakes, etc.. SO I can use those..
..WHAT gives these motors the lower compression ratio? (If I am remembering right).. Would I be better off turboing the lower compression ratio LQ1? I am stuck rebuilding my 96 because I cant get a grip on the crank pulley and sprocket to remove everything else in there to get it cleaned in honed..
..I just want to make sure I am using the best block for what I want to do.. Thanks for helping me out with all my noobness on rebuilding the DOHC!!
